ways of load balancing to WAN
carl_townshend
Hi all, if I wanted to load balance traffic out of my wan using 2 routers, how would this be done, I know that they routing protocol will load balance but how would I send the traffic to the 2 routers,
are the 2 options, 2 static equal cost routes, and glbp?
cheers
Carl
cisco_lad2004
Level 5
Level 5
Equal path routing and GLBP would both achieve what you want.
Etherchannel is also an option.
Sam
jgreenwoodii
Maybe I'm reading to much into the question but curious if you have 2 WAN circuits terminating on 2 individual routers or is the topology using 2 routers connected to a Single Wan Router?
jgreenwoodii
Jonathan
