wccp redirection
draganskundric
Level 2
Level 2
in manuals that describes wccp redirection it is
described something like this
interface input
ip wccp 61 redirect in
interface output
ip wccp 62 redirect in
can I use this config
interface output
ip wccp 61 redirect out
instedad of redirecting on inpute interface?
Giuseppe Larosa
Hello Dragan,
the answer is that it depends from platform in use.
some support only redirection on the inbound interface/direction
for example C4500 or ASR 1000
see
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_wccp_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1054493
also you should check to see where the web caches are located out interface number2 or out a third interface?
Hope to help
Giuseppe
