wccp
catalystexpress
Level 3
Level 3
Hi All,
I have configured wccp on my 2811 router for the topology as below the "redirect in" command is applied on the router's interface connecting to the core switches, everything seems to work except that i cannot see a particular ip 10.6.1.xx to 10.3.1.xx on location A silverpeak, however i can see the 10.3.1.xx to 10.6.1.xx on location B silverpeak, however i can see 10.6.1.y to 10.3.1.y on location A and B, its just this particular IP, my acl allows 10.6.1.0/24 to 10.3.1.0/24 on both locations and since i see other packets from same subnet being optimized i do not see a issue with ACL
Is there a command to show if this particular ip is hitting the acl and is being redirected as per wccp or any suggestion please
          Location A                                      Locatino B
silverpeak A --- router01 --- MPLS --- router01 -- silverpeakB
silverpeak A --- router02 --- MPLS -- router02 --- silverpeakB
many thanks
cheers
LA-Engineer
Level 4
Level 4
Does 'sh ip access-list' tell you the hits?
