Web Server load balancing and ASA
Zayar Win
Dear All,
                In this Case, I will make load balancing the two web server. How should I do?
My Requirement is I need load balance to two web server from Load balancer. I think ASA should not do NAT in this case. ASA only need to pass transparent. How do you think?
2 Accepted Solutions
As I see in your topology, your load balancer is translating your public IP addresses to private IP addresses on your web servers.  In this case, ASA only need to allow HTTP traffic from external security zone to DMZ(from any to your web servers). It does not need to translate(NAT) one more time.
Hope it helps,
Masoud
1- You need to assign the server IP addresses on your load balancer.
something like this
Server farm = 172.16.10.30 and 172.16.10.31
Public IP>>> server farm
2- You also need to configure route toward ASA on your load balancer if you did not before
I am not familiar with your load balancer. I am using Cisco command instead
On your load balancer
ip route 172.16.10.30 255.255.255.255 192.168.100.1
ip route 172.16.10.31 255.255.255.255 192.168.100.1
3- permit HTTP traffic from any to 172.16.10.30 and 172.16.10.31  on ASA
Hope it helps,
Masoud
10 Replies 10
Hope it helps,
Masoud
Hi Masoud,
              Yes, you I am same to you. In this case,  two web server are not directly connected to load balancer .There are two network behind the Load balancer. So , which  address should assign in load balancer? DMZ network is 172.16.x.x and Between ASA and F5 is 192.168.x.x  . Therefore I am still confusing .
zayar
something like this
Hope it helps,
Masoud
      My network is a little bit complected so, I will make Static NAT in ASA ,
192.168.100.21 => 172.16.10.31 (web server real ip)
192.168.100.22 => 172.16.10.31 (web server real ip)
Please let me have the command for ASA to make Static NAT and to open port 80 to DMZ for outside.
What is your ASA OS version?
What are names of your ASA interfaces? Inside, outside and DMZ?
ASA-5510  OS 8.4
ASA interfaces - Inside , outside and DMZ , yes right.
Your original post was
I changed the real server IP in my configuration.
Add this configuration and check to see if you get error. I will give you the access-list in the following post.
object network STATIC_NAT_SERVER1
 host 172.16.10.30
 nat (DMZ,outside) static 192.168.100.21
object network STATIC_NAT_SERVER2
 host 172.16.10.31
 nat (DMZ,outside) static 192.168.100.22
Thanks you, and give me next access list command  to open some specific port (outsite to DMZ web server  ) especially port 80 for this case.
access-list web-servers extended permit tcp any host 172.16.10.31 eq www
access-list web-servers extended permit tcp any host 172.16.10.30 eq www
access-group web-servers in interface outside
Check my previous comment for NAT. This one is for access-list.
Hope it help,
Masoud
