webEX prioritization
david-aliata
Hi Guys,
I want to have users access to the site www.webex.com as high priority, and the other web sites are still set as the lower priority.How would i
accomodate this on my Cisco 1941 configutration below ?
class-map match-any p2p
match protocol bittorrent
match protocol edonkey
match protocol fasttrack
match protocol gnutella
match protocol kazaa2
class-map match-all voice_sig
policy-map wan_qos
class p2p
    police 8000
class voice
    priority percent 50
class voice_sig
    bandwidth percent 10
class class-default
    fair-queue
policy-map input
class p2p
    police 8000
interface GigabitEthernet0/0
ip nat outside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
no cdp enable
service-policy input input
service-policy output wan_qos
interface GigabitEthernet0/1
ip address 192.168.1.1 255.255.255.224
ip access-group netbios in
ip access-group netbios out
no ip proxy-arp
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip flow-export version 5
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 *.*.
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
Thank you,
David
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
For www.webex.com, if you believe its IP(s) will remain static, you might prioritize based on the IP address.  If your 1941 supports the "right" NBAR, you also might prioritize using NBAR matching against the host (see http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6558/ps6616/qa_c67-646888.html).
Other web sites could be left in your default class or placed into a separate class just for HTTP.
