WebGUI SSL Protocol Error on Catalyst 9500-48Y4C
baronfunke
Working through my (very newbie) CLI syntax and wanting to double-check myself in the GUI, but I keep getting the ERR_SSL_PROTOCOL_ERROR when connecting.
I set the IP and subnet of the management port, it's pingable, I even get redirected to the 'webui' subfolder, but getting stopped.
I've tried all browsers, multiple computers, clearing caches, nothing seems to work.
Also updated to current supported OS (17.12.04), which erased the old config (which is a blessing in disguise), but no luck.
I did also notice that I only have the SLA-TrustPoint PKI certificate chain installed, none of the self-signed certs, so maybe that's the culprit?  I was able to get on the WebGUI when I initially installed it (in 2020), but no luck now.
@baronfunke
 what about HTTP?
Make sure you have  " ip http server" command for HTTP
For HTTPS, you may reset the HTTP server by using
no ip http secure-server
and
check the interface the switch is using for web
ip http client source-interface  XXXX
check if everything is up and running with
sh ip http server all
Can you share config of SW
MHM
baronfunke
Sorry it took so long for a reply, but finally got everything re-stacked and digging in to this obstacle.   I did the "shut/no shut" on http-sercure server, but couldn't get "ip http client source-interface XXXX" to work, as I wasn't sure which interface to put in there (I haven't tagged anything specific to be using the web portal).
I've attached my current config
