03-24-2017 12:42 AM - edited 03-08-2019 09:53 AM
7609(config-router)# address-family ipv6
% Topol¥@ogy global::IPv6 Unicast::base@ is cur¥rently being dec¥onfigured.
i can't go into address family
03-24-2017 05:11 AM
Are you removing any VRF associated to this AF? Try to enable mls ipv6 vrf before
If you are using 'definition vrf' create the AF there as well, example:
mls ipv6 vrf
vrf definition Test
rd X:Y
address-family ipv4
route-target.....
address-family ipv6
route-target.....
Please rate the comment if it is useful
03-29-2017 04:29 AM
Hi,Julio,
we config this command under router bgp 100, not in vrf.
we once deleted this command and re add it under router bgp 100. but failed, before this ,we can config this command.
thank you
Tom
