Weird problem with HSRP in 6509
joshiaroon
subnet used 10.1.6.128/28
top 6509
interface Vlan61
description mail-voip vlan
ip address 10.1.6.131 255.255.255.240
no ip redirects
standby 61 ip 10.1.6.129
standby 61 timers 5 15
standby 61 priority 90
standby 61 preempt
standby 61 authentication dc26
bottom 6509
interface Vlan61
ip address 10.1.6.130 255.255.255.240
no ip redirects
standby 61 priority 80
standby 61 preempt
top# show standby
Vlan61 - Group 61
  Local state is Active, priority 90, may preempt
  Hellotime 5 sec, holdtime 15 sec
  Next hello sent in 2.866
  Virtual IP address is 10.1.6.129 configured
  Active router is local
  Standby router is 10.1.6.130 expires in 10.156
  Virtual mac address is 0000.0c07.ac3d
  Authentication text "dc26"
  1 state changes, last state change 24w2d
  IP redundancy name is "hsrp-Vl61-61" (default)
bottom#show standby
Vlan61 - Group 61
  Local state is Standby, priority 80, may preempt
  Next hello sent in 3.894
  Active router is 10.1.6.131, priority 90 expires in 11.632
  Standby router is local
  7 state changes, last state change 24w0d
the problem (corrected): HSRP should be using 3 ip per subnet right? one for VIP and other two for top and bottom switch.
But in my scenario when i telent to 10.1.6.143, it point to top 6509.
is there something i am missing? thanks
5 Replies 5
Reza Sharifi
can you provide "sh spanning-tree vlan 61" from both switches?
it may be that connection from the edge to your top 6509 is in blocking mode
also, you wrote:
when i telent to 10.1.143, it point to bottom 6509.
I don't see this IP in your config
Reza
yeah, i agree. it seems a typo that he put 10.1.143 (first it is not valid ip to begin with. ) so until he can clearify that we wont be able to help.
mlund
Level 7
Level 7
It may be a typo, but You telnet to 10.1.143. That is not a correct ip address.
I have seen unixhost treating a telnet such that as 10.1.0.143.
Also if it is 10.1.6.143 you telnet to, that is the broadcast address for the subnet.
/Mikael
ok i am attaching the telnet to 10.1.6.143 and i also issue show ip int br command. Thats the problem guys, i even did not see the ip address in the 6509
Got it, in HSRP , if we telnet to broadcast ip. i will point to active router.
Thanks Guys for all your inputs.
