What am I doing wrong?
Murray Bown
Level 3
Level 3
I have just go a new 2911, it has 3 GB interfaces. the first gi0/0, is configured for WAN access and gi0/1 is configured as a LAN. Now when I try to access the internet from the LAN interface it just fails, I can ping the internet from the WAN interface but not from the LAN interface. Can someone have a look at my config and let me know "What am I doing wrong?"
interface GigabitEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ETH-WAN$$FW_OUTSIDE$
ip address 194.73.xxx.xxx 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
ip verify unicast reverse-path
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description $ES_LAN$$ETH-LAN$$FW_INSIDE$
ip address 172.19.20.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no mop enabled
ip route 0.0.0.0 0.0.0.0 194.73.xxx.xxx
Reza Sharifi
Can you also post your NAT statment and access list?
