what does sh controller T1 command shows
mahesh18
Level 6
Level 6
Hi all i have this info
#sh controller t1
, 0 Line Code
T1 4/0/4 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
Description: P2P T1 to E&P Aztec, NM (nmaztr1 S0/0/0) UCN #DS1-10663022
No alarms detected.
alarm-trigger is not set
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
Data in current interval (2 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 86 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
T1 4/0/5 is up.
Description: T1 to Quailey Peak (W0B-57107)
No alarms detected.
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
T1 4/0/6 is up.
Description: T1 to Geismar, LA WorldCom # W0N-23488
No alarms detected.
0 Line Code Violations, 1 Path Code Violations,
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 4/0/7 is up.
Description: T1 to Geismar, LA Verizon Circuit ID: W0S-98733
No alarms detected.
0 Line Code Violations, 22 Path Code Violations,
0 Slip Secs, 4 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
14 Errored Secs, 6 Bursty Err Secs, 4 Severely Err Secs, 12 Unavail Secs
i this command for example 3/1/1 means
module/bay /slot--
my understanding is module 3 which is big
device and bay is card inside that has 8
slots or ports
is there any site where i can see the image of this Flexwan controller card
Richard Burts
Mahesh
This link has a picture of the flexwan card:
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/multichannel_serial/8-port_multichannel_t1.ei_8pri_install_config/2738ovr.html#wp1050186
and earlier in the article it has a picture of the 8 port T1 which can be used in the flexwan card.
Rick
Rick
Richard Burts
Mahesh
Rick
Rick
Hi rick
thanks for reply
i got ot now
