08-19-2025 09:54 AM - edited 08-19-2025 09:56 AM
I have a very basic question
---> Asking in chatxxx:
Question:
From a software or programming perspective, what is an offset?
Answer:
In programming, an offset refers to a number that indicates the distance (or displacement) from a starting point, typically in memory or data structures.
Common Contexts Where "Offset" Appears:
1. Memory Offsets
2. File Offsets
3. Array or Buffer Indexing
4. Data Structure Fields
5. Paging or Virtual Memory
Summary Definition:
An offset is a numerical value that specifies how far (in units like bytes, elements, etc.) a certain location is from a defined base or start point.
* With the above information...
---> My question is:
For a PENTESTER an OFFSET (in a programming code) is an address of a pointer or are several things (depending on the context)?
Thanks for the information
Solved! Go to Solution.
08-19-2025 10:03 AM
@A3XN In pentesting, an offset is the distance (in bytes) from the start of ur input or buffer to the point u want to reach, such as the saved return address or instruction pointer during a buffer overflow. It’s not the actual memory address or pointer itself, but rather the displacement that tells u where in the data the overwrite happens. Depending on context, offsets can also describe positions within structures or memory layouts, but the idea is always the same: a relative position from a base point..........
hope it helps and PEACE!
-Enes
08-19-2025 10:03 AM
-Enes
08-20-2025 02:16 PM
Thank you
Now I understand the concept better
08-19-2025 04:57 PM
I would start with Google AI to search basic info, then refer to your study materials
Regards, ML
**Have fun labbing!!!***
***Please Rate All Helpful Responses ***
08-20-2025 02:17 PM
Thanks for the tip
