what is customer edge router and provider edge router
mahesh18
Level 6
Level 6
Can someone explain we what is CER and PER and in which network we use them?
2 Accepted Solutions
Richard Burts
mahesh
We frequently see these terms used in MPLS networks. the Customer Edge Router (CER) is the router on the Customer side of the connection and that provides connectivity to the interior of the Customer network and to the MPLS cloud. the Provider Edge Router (PER) is the router on the Provider side of the connection and that provides connectivity from the MPLS cloud to the Customer network.
Rick
Rick
mahesh
I am glad that the answers that Sundar and I provided were able to resolve your question. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read responses that did resolve the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
Richard Burts
mahesh
Rick
Rick
Thanks for your reply Rick.
so PER is physically located at Telco office
Right?
Mahesh,
No, that would be on the MPLS service provider, not Telco, side facing the customer. PEs usually sit on the edge of the MPLS cloud and connect to the CEs that are usually located at the customer premise.
Sundar
mahesh
Rick
Rick
