What is meant by fabric
Jonn cos
Level 4
Level 4
Guys,
I am really confused by this world especially in cisco terminology. What is actually meant by a fabric ?
Karan Puri
In simple the channel which connects asic port and PFC..
Sent from Cisco Technical Support Android App
edsge teenstra
First Cisco supervisors did not have a switch fabric : http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c6652.shtml
Then the SUP720 came for the Catalyst 6500 series chassis increasing bandwidth from classic bus 32Gbps to S2/MSFC2+SFM-module = 256Gbps (dCEF256/CEF256) to finally (CEF720/dCEF720) and as last VS-S2T with 2Terabit per second forwarding performane.
The Supervisor engine 720 integrates a high-performance 720 Gbps crossbar switch fabric with a forwarding engine in a single module, delivering 40 Gbps of switching capacity per slot (enabling 4-port 10GE and 48-port 10/100/1000 density line cards). http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856.html
Finally good reading:
http://etherealmind.com/what-is-the-definition-of-switch-fabric/
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"Fabric" normal refers to a cross-bar architecture between ports or channels.  Note - often multiple edge ports (i.e. ports you connect devices to) are connected to the same fabric port or channel.
The important feature of a "fabric" is, any pair of its (fabric) port or channel can send/receive from another port or channel without regard to what's happening between other ports or channels.
Karan Puri
In addition to joseph comments, if u have classic line card in your chasis then communication will happen via classic bus channels ... there are types of bus for management n data traffic u read in cisco doc...
