What is the difference between SFP-GE-T and GLC-T?
astanislaus
Level 2
Level 2
I have some information from this link, but I need to know if I could one for the other.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
8 Replies 8
andrew.burns
Level 7
Level 7
They are operationally identical and can be interchanged with no problems - the only difference is that the SFP-GE-T conforms to NEBS Level 3 and the GLC-T doesn't. (Well, I think the SFP-GE-T costs a bit more too..)
HTH - plz rate useful posts (not just mine!)
Andrew.
Thanks for the immediate reply. What is NEBS Level 3 and DOM. Anyway don't worry I will GOOGLE it.
It's easy to find the "what" of NEBS, but slightly harder to find the "why" of NEBS, which is nicely explained here:
http://www.ce-mag.com/archive/03/03/nebs.html
Andrew.
I'll also add that the SFP-GE-T is a little bit more expensive...maybe $40 more (retail) but it works in switches or routers like the ASR while the GLC-T is for switches only. I learned the hard way.
What happens when you put a GLC-T into a router?
Does it give you some sort of error message?
for me , GLC_T didnt work in ASR 1002x, but did work on ASR1001x.
dont know why, so i buy SFP_GE_T for Routers.
Ahmed, I have asro1002-x but SFP_GE_T is not wokring... can you give mt the exact nmodel numbers?
Make sure you check the compatibility matrix here. It also depends on the software you are running on the platform.
GE Transceiver compatibility Martix
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
