What is the maximum throughput of ISR 4331?
turkays
Hallo,
Kann jemand bestätigen, dass der Cisco ISR 4331-Router Ethernetchannel unterstützt? Wenn ja, können wir dann den I SR Router 4331 mit 2960-X-Stack-Switches verbinden (verschiedene Mitglieder verwenden die Router-Konnektivität).
The Cisco ISR4331-AX/K9 is a rack-mountable router that delivers 100 Mbps to 300 Mbps aggregate throughput.
Der Link zum Referenzdokument wird sehr geschätzt.
What is Cisco ISR 4331 router?
Cisco ISR4331/K9 Price - Buy Cisco 4331 Integrated Services ... Cisco 4331 Integrated Services Router delivers 100 Mbps to 300 Mbps aggregate throughput and offers one Enhanced service-module (SM-X) slot, which supports for both single- and double-wide service modules provides flexibility in deployment options.
Can you do EtherChannel on a router?
EtherChannel provides fault-tolerant high-speed links between switches, routers, and servers. EtherChannel allows multiple physical Ethernet links to be combined into one logical link.
How do I create a port channel on my Cisco router?
You create a port channel by bundling compatible interfaces. You can configure and run either static port channels or port channels running the Link Aggregation Control Protocol (LACP). Any configuration changes that you apply to the port channel are applied to each member interface of that port channel.
What is the max throughput of Cisco isr4321?
It delivers 50Mbps thoughtput by default. With pay-as-you-grow performance, you can increase forwarding capacity to 100Mbps by buying FL-4320-PERF-K9 licenses.
What is the performance of Cisco ISR 4k?
It offers 50-Mbps performance, upgradable to 100 Mbps, in a 1RU desktop form factor with two NIM slots and no SM slots. The Cisco 4000 Series is designed to help branch and remote offices do more with less. These routers provide higher bandwidth for heavy service combinations and greatly enhanced WAN management.
the throughput depends on the license. Use the command:
show platform hardware throughput level
to display the currently configured license/throughput. The base license throughput is 500MB.
The 4431 definitely supports Etherchannel.
M02@rt37
Hello @turkays
ISR4331 support EtherChannel.
As concerned performance licence, follow thes links
https://www.cisco.com/c/en/us/support/docs/routers/4000-series-integrated-services-routers/217135-performance-license-on-cisco-isr4000.html
Also see here table 6 : FL-44-PERF-K9
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
Best regards
