What is throughput of 6500 and 6800 series
mohammad saeed
Level 5
Level 5
Hi Guys,
Is there any technical datasheet from Cisco tells how much the throughput of Core switches 6500 or 6800?
Thanks for all
Mohammad Saeed
Reza Sharifi
There are different models of 6800 series.  Here is the data sheet for the 6807 switch. 6800 the replacement for the 6500 series.
Capable of delivering up to 11.4 terabits per second of system bandwidth capacity and 880 Gbps of per-slot bandwidth for all slots.
A system configured for VSS is capable of delivering 22.8 terabits per second of system bandwidth.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6807-xl-switch/data_sheet_c78-728229.html
Thanks Reza, but no mentioned about throughput! because old 6509 data sheet was mentioned but nowadays they remove it...Am I right?
Hi Mohammad,
Depends on the model you are looking for. Here is the data sheet for the other 6800 models.  See table-2
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6840-x-switch/datasheet-c78-734470.html
