06-26-2013 02:47 AM - edited 03-07-2019 02:05 PM
what license does VSS need in 4507R chassis?
1. IP base
2. IP services
Which soft i need to choose in CCM?
Cisco CAT4500E IOS ENTERPRISE or CAT4500e SUP7-E/SUP7L-E Universal or BASE?
Solved! Go to Solution.
06-26-2013 04:36 AM
Fedor,
Not sure if you read my post.
VSS will work without IP services license. There is no need to have the ip services license to use this feature.
If you just have base license that is sufficient to use the VSS feature.
Minimum license : IP Base or higher (7-E) or special license (7-LE and Catalyst 4500-X).For information about Software Activation Licensing please refer
Below is the ref on configuring and other details of VSS on Cat 4500.
Inayath
*Please rate if this has help you and mark as answerd if this thread has answered your query.
06-26-2013 03:05 AM
Fedor,
The 4500X switch the feature VSS is supported on IP-Base.
Is there any info on the VSS license for SUP7L-E ?
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_27990-01.html
Under Table 5 - Support by Image Type; VSS is listed as available on IP Base (SUP7E only) and a plain Yes under Enterprise Services
http://www.cisco.com/en/US/prod/collateral/switches/ps10902/ps12332/at_a_glance_c45-696645.pdf
Under Table 1 - Minimum License for VSS; IP Base or higher (7-E) or special license (7-LE and Catalyst 4500-X)
There appears to be no option on the CCO configuration tools to add VSS license on 4500R+E chasiss bundles with for example dual SUP7L-E and IP Base
REgards
Inayath
*Plz rate al usefull posts.
06-26-2013 04:12 AM
So, one more time, will VSS works without IP Services license on 4507R+E chassis with supervisor WS-X45-SUP7-E?
06-26-2013 04:36 AM
Fedor,
Inayath
06-26-2013 04:49 AM
VSS will work with plain IP Base.
Not sure if this is the same with the Sup8E.
05-05-2014 11:34 PM
In case of Sup7L-E will vss works with ip base license?
