What Power Adapter comes with SG350-10-K9?
Mochalattedev
Basically the title. Purchased one for a start up, but it didn’t come with a power adapter, and I can’t seem to find any good resources pointing me to which one I need to buy.
I saw the FSP-090 AWAN3 was recommended for the SG350-10P-K9, but that switch supports PoE, and mine doesn’t. Would that one work?
Thank you.
Hello @Mochalattedev ,
the SG350-10P-K9 is the correct part number for the power supply. It will work with your SG350-10-K9 even if yours doesn't have POE.
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
Ty so much.
