what switches support vlan mapping?
networkadmin411
Is there a list of switches that support vlan mapping?
@networkadmin411  Hello,
SW04(config)#vlan access-map TESTE 10
SW04(config-access-map)#
SW04(config-access-map)#?
Vlan access-map configuration commands:
action Take the action
default Set a command to its defaults
exit Exit from vlan access-map configuration mode
match Match values.
no Negate a command or set its defaults
SW04(config-access-map)#do sh ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 22-Jan-18 04:41 by prod_rel_team
2960X working without problem.
Here doc to vlan mapping: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/vlan/configuration_guide/b_vlan_152ex_2960-x_cg/b_vlan_152ex_2960-x_cg_chapter_011.html
Certainly also 3750 works.
Jaderson Pessoa
*** Rate All Helpful Responses ***
5 Replies 5
Jaderson Pessoa
as i know... Catalyst family 2960 and above :)
Jaderson Pessoa
That is what I thought as well but I am having trouble with my 3750x and 2960x. not able to find documentation on vlan mapping for them.
match Match values.
Jaderson Pessoa
Thank you for the info!
you're welcome. :)
Jaderson Pessoa
