When I disable Ip Cef, PBR will work
chhayheng
Hi Guys,
I have a small question regarding IP CEF with PBR on IOS (7200 Software (C7200-P-M), Version 12.2(15)T17, RELEASE SOFTWARE (fc1)) GNS3.
When I enable IP CEF on global mode, my PBR not work anymore till i disable IP CEF on global mode, then my PBR work.
Anyone knows this issue ?
Best Regards,
Chhayheng
Mark Malone
Thats an old image 5yrs old in an emulator as well you could have hit a bug , pbr can work with or without cef but its always recommended to have it on as its an enhancement even with pbr
when you enable cef with pbr its better performance as its moved off fast switching to express
first thing i would do is try another image see if its the same as its in gns3
