where is the running and startup configs stored
carl_townshend
Hi all
where is the running and startup configs stored on my switches and routers, and can I see them in a directory ? I cannot see them in flash.
9 Replies 9
NickNac79
Startup config is held in flash.
e.g.
config.text
vlan.dat
private-config.text
Running config is in memory.
Nick
so, does the running config and startup config always have to be called that?
so you say the startup config will be called config.text ?
Carl,
Try:
dir nvram:
Your startup config is called startup-config, and it has to be that that I'm aware of.
HTH,
John
HTH, John *** Please rate all useful posts ***
That is the name of the file in flash, yes.
No Startup-config and running-config cannot be renamed.
Nick
greg.washburn
system:running-config
nvram:startup-config
to see them issue
dir system:
dir nvram:
nvram = flash basically
system = ram basically
so how come if I do, sh flash, its not shown in there ?
so is nvram really flash ?
Hi Carl,
Yes NVRAM is Flash Memory
(Non-Volatile RAM)
System: is a RAM drive.
Run the following commands:
dir system:
dir nvram:
dir flash:
You'll notice that the filesize of nvram:startup-config and flash:config.text are the same.
As are nvram:private-config and flash:private-config.text.
They're just two different ways of accessing the same files.
Was there a reason that you asked? Were you just curious or did you want to know how to do something?
Nick
just curious as always :-)
Cool :-)
Please rate any posts that you found useful.
Nick
