11-24-2011 11:39 PM - edited 03-07-2019 03:35 AM
Hi all.
While running HSRP on Layer 3 swithces and if OSPF is running between them
i have seen that if we make standby switch as DR and active switch as BDR it slows the telnet access to active switch and also slows tha LAN traffic.
so in HSRP network does it matter which switch active or standby should be DR or BDR ?
Also can someone tell me why network is slow if standby switch becomes BDR?
And is both switches connect to WAN router then is it ok by network design to make WAN routers both interfaces as DR?
Mahesh
Solved! Go to Solution.
11-25-2011 10:40 AM
Hi Leo,
Thanks for reply.
On A and B switch i have only this network statement
network 192.168.0.0 0.0.255.255 area 0
And both A and B switches shows 3 vlans as neis .
Can you please tell me how can i remove several paths from same trunk link?
thanks
mahesh
11-25-2011 10:46 AM
Just replace the /16 network statement by several /24 nets:
3550SMIA
network 192.168.10.0 0.0.0.255 area 0
network 192.168.5.0 0.0.0.255 area 0
3550SMIB
network 192.168.6.0 0.0.0.255 area 0
Leo
11-25-2011 07:49 PM
Hi leo
i did this on Switch A and B
network 192.168.20.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
but on Switch A i still see all 3 vlans as neighbors
3550SMIA#sh ip ospf nei
Neighbor ID Pri State Dead Time Address Interface
192.168.30.2 1 FULL/BDR 00:02:33 192.168.30.2 Vlan30
192.168.30.2 1 FULL/BDR 00:02:33 192.168.10.2 Vlan10
192.168.30.2 1 FULL/BDR 00:02:33 192.168.20.2 Vlan20
192.168.6.3 1 FULL/DR 00:02:02 192.168.5.3 FastEthernet0/11
thanks
mahesh
11-25-2011 11:31 PM
But you did not do exactly what I said.
You have added all three vlan networks where I specified only vlan 10.
11-26-2011 12:31 AM
Hi Leo.
Thanks for reply.
Now what i did is switch A
3550SMIA# sh ip ospf nei
2.2.2.2 1 FULL/BDR 00:02:32 192.168.20.2 Vlan20
4.4.4.4 1 FULL/DR 00:02:07 192.168.5.3 FastEthernet0/11
Vlan 20 has wi fi network so i run the ospf on vlan 20 only.
other vlans 10 and 30 no ospf is running now as per below.
this means if any users connect to vlan 10 and 20 then they can not connect to the internet right ???
as no OSPF is running on vlan 10.
3550SMIA#sh ip ospf int vlan 10
%OSPF: OSPF not enabled on Vlan10
question in order to run ospf on vlan 10 i need to run the command
network 192.168.10.0 0.0.0.255 area 0 right??
network 192.168.5.0 i used on A switch as it connects to the Internet router.
thanks
mahesh
11-26-2011 01:07 AM
If the two switch is in high availability with ospf, and on all vlan there are only host if i have understand correctly, why do not configure interface in passive state and use ospf only on interface connected to Router internet? Or maybe there are other router that need to communicate on each vlan?
11-26-2011 09:03 PM
Hi Fabio,
Thanks for reply.
Switches A andB are running HSRP.
Currently VLAN 20 is running which has wi fi connection for users.
So OSPF is running on it.
If i do not run OSPF on VLAN 20 then no internet connections as i am not advertising 192.168.20.0 network to Internet router.
So between Switch A and B currently OSPF is running on VLAN 20 and each switch interface that connects to the
Router.
So as per you note can i config VLAN 20 in Passive state?
If i config the VLAN 20 as passive state as per my understanding internet will not work.
Correct me i am wrong.
MAhesh
11-26-2011 11:46 PM
Ospf must be configured with command network for all subnet or range of subnet you want advertise, but only on vlan or interfece where there is a router to form a neighborship, if you put interface in passive state ospf continue to send advertisement about that interface but doesn't send multicast hello an all interface where there are not router to form a neighborship. Is not necessary to send a lot of multicast hello to 224.0.0.5 to the host client. If two switch are in hsrp all client can reach both switch by layer 2, and layer 3 protocol routing is only needed vs router internet to announce inside network.
11-27-2011 11:19 AM
Hi Fabio,
Thanks for reply.
Here is what i did --
1>Both switches are still advertising network 192.168.20.0
2>On HSRP switches A and B i did this
router ospf 1
passive-interface vlan 20.
Now when i run command --- sh ip ospf nei
4.4.4.4 1 FULL/DR 00:02:38 192.168.5.3 FastEthernet0
It do not show Switch B as nei -- This is normal behaviour as now we do not nei adjancey with B switch Right?
Same thing on B switch - it does not show switch A as nei.
*******************************************************************************************************************8
when i do sh ip ospf int
switch A
Vlan20 is up, line protocol is up
Internet Address 192.168.20.1/24, Area 0
Process ID 1, Router ID 3.3.3.3, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 3.3.3.3, Interface address 192.168.20.1
No backup designated router on this network
Timer intervals configured, Hello 40, Dead 160, Wait 160, Retransmit 5
oob-resync timeout 160
No Hellos (Passive interface)
Switch B
3550SMIB#sh ip ospf int
Internet Address 192.168.20.2/24, Area 0
Process ID 1, Router ID 2.2.2.2, Network Type BROADCAST, Cost: 1
Designated Router (ID) 2.2.2.2, Interface address 192.168.20.2
Now Both switch A and B show as DR and they have no backup Router --- is this due to the reason that we have
made vlan 20 as passive and it is not sending any hellos and both A and B switches elected their VLAN 20 interface as
DR.
Also when i do sh ip route vlan 20 IP on both switches it shows
3550SMIB#sh ip route 192.168.20.3
Routing entry for 192.168.20.0/24
Known via "connected", distance 0, metric 0 (connected, via interface)
Routing Descriptor Blocks:
* directly connected, via Vlan20
Route metric is 0, traffic share count is 1
So correct me if i am wrong this means that both switches can reach their VLAN 20 IPs via vlan 20 and this info
is passing through trunk ports on the switch??
Mahesh
11-28-2011 12:19 AM
Yes Mahesh, your switch are linked in layer 2 the communication betwen switch is not performed by routing protocol, and there are only client on vlan 20, the switch communicates directly because on the same lan, and also both switch continue to advertise the route of your vlan 20 to internet router in ospf.
Now your network works correctly and with more performance?
11-28-2011 09:57 PM
Hi Fabio,
Thanks for reply.
I read the info below ---
So by doing interface as passive is to advertise the IP network configured on such an interface as an internal OSPF network.
Can you please explain me what does it mean by internal ospf network?
Right now current switch processing is ok.
It droped after config of interface as passive.
MAhesh
11-29-2011 12:01 AM
I don't understand what you intend for internal ospf network, but an interface must be in active state when on lan segment there are one or more router who need to do a neighborship, to exchange routing table. Your second switch and your primary switch is on the same network so there isn't a network behind a router or switch but all your equipement known the same vlan and are default gateway of the same network by hsrp. If there was a router or switch with a network behind not reachable by layer 2 in this case ospf and routing (or static route) is needed.
12-02-2011 08:18 AM
Hi Fabio and Leo,
Many thanks for spending your time to explain me about the network setup in depth.
Mahesh
