WHY AM I NOT ABLE TO CONFIGURE OSPF in multilayer switch catalyst 4948
murtaza123456
Switch# show version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-LANBASE-M),
Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 12:24 by
Image text-base: 0x10000000, data-base: 0x128316E0
ROM: 12.2(44r)SG11
Hobgoblin Revision 21Fortooine Revision 1.22
POPS-backbone-Switch uptime is 2 minutes
System image file is "bootflash:cat4500e-lanbase-mz.122-54.SG1.bin"
cisco WS-C4948E (MPC8548) processor (revision with 1048576K bytes of
memory.
Processor board ID CAT1643S11J
MPC8548 CPU at 1GHz, Cisco Catalyst 4948E
Last reset from Power Up
11 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
#show  I p route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
I - IS-IS,  - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
IA - IS-IS inter area, * - candidate default, U - per-user static
route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
Leo Laohoo
@murtaza123456 wrote:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-LANBASE-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Because the IOS Feature is "lanbase" which is anything Layer 2.
For routing, use IP Services feature set.
BTW, although I recall your 4948 may run an IP Services IOS, legally you'll need the license for it too.
But, but, but when I downloaded the file from torrent, I did not have a choice!
