Why service-policy is not generated after using auto qos voip?
wfqk
Level 5
Level 5
In SW3560, after the command "auto qos voip cisco-phone" is typed under the interface, the expected service-policy is not generated in interface level and global level. Please see the below.
i reviewed document, which suggests remove the command and retype it. after i did it, the service-policy still cannot appear. What is issue? Thank you
interface GigabitEthernet0/1
 srr-queue bandwidth share 10 10 60 20
 srr-queue bandwidth shape  10  0  0  0
 queue-set 2
 mls qos trust device cisco-phone
 mls qos trust cos
end
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2  1
mls qos srr-queue input cos-map queue 1 threshold 3  0
mls qos srr-queue input cos-map queue 2 threshold 1  2
mls qos srr-queue input cos-map queue 2 threshold 2  4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3  3 5
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3  32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3  5
mls qos srr-queue output cos-map queue 2 threshold 3  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3  2 4
mls qos srr-queue output cos-map queue 4 threshold 2  1
mls qos srr-queue output cos-map queue 4 threshold 3  0
mls qos srr-queue output dscp-map queue 1 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3  48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3  56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3  16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3  32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1  8
mls qos srr-queue output dscp-map queue 4 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3  0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
11 Replies 11
is this the full port configuration:
queue-set 2
mls qos trust cos
According to the guidelines, you can enable auto-QoS on static, dynamic-access, voice VLAN access, and trunk ports. Add either 'switchport mode access' or 'switchport voice vlan' to the port. What is the port used for anyway ?
Thank you so much for your reply. The interface is used for user pc and ip phone. I am trying to test Qos in lab before pushing it to network. so i forgot to add data vlan and voice vlan.
So maybe after adding data vlan and voice vlan, the service-policy will get created? i am going to add these two vlan next day for test. Thank you!
In theory that should work. Let us know the results...
I could be wrong here but on the 3560s from memory its IOS so it doesn't actually add the service policy to the interface on a layer 2 interfaces it just applys the qos , it does on IOS-XE with auto qos on a 3650 it creates full maps then applies it to each individual interface that has auto enabled
You can check your qos is working with show mls qos interface gx/x statistics
also in your post your best off using DSCP if available rather than COS and set the uplink to trust DSCP too , most new phones etc send in DSCP now
Joseph W. Doherty
I recall (?) on that series, once auto QoS commands have been triggered, they are not regenerated unless you completely remove all of them from the device. This, I believe, was allow you to "customize" the auto QoS generated commands after they are installed the first time.
i removed all configuration and add auto qos and vlan for voice and data at interface. the policy-map was not generated
How did you remove all the config? Reason I ask, I don't recall exactly what I've done in the past to reset the auto QoS regeneration trigger, but if you're in a position to try it, erase the startup config (you can save a copy under a different file name) and reboot. See if that then allows for a reset of auto QoS. (You can then [later] either copy it to startup or merge it with running and re-save.)
BTW, auto QoS generation might also require QoS be enabled.
Yes i erased start-config in nvram and reload it. then confirm all are gone. after that, i tested auto qos. all results are same as last time. tomorrow i will test it again
my 3560s dont contain policy's either running qos interface or global as i was saying in earlier post i dont think they do in general
I just tested it on a fresh non qos 3560 to be sure same results no policies ingterface or global but qos is working fine
I dont think you have any issue
#show auto qos interface fa0/12
FastEthernet0/12
auto qos trust
Model number : WS-C3560V2-48PS-S
* 1 52 WS-C3560V2-48PS
interface FastEthernet0/12
switchport access vlan 4
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
spanning-tree portfast
sh mls qos interface f0/12 statistics
FastEthernet0/12 (All statistics are in packets)
dscp: incoming
0 - 4 : 14477 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 697966
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 2239979 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
And mls qos was enabled before entering an interface auto QoS command too, correct?
What specific 3560 model and what IOS is running on it?
i tested it on this
xxxxxx#sh ver | i 3560 | image
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 15.0(2)SE11, RELEASE SOFTWARE (fc3)
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(50r)SE, RELEASE SOFTWARE (fc1)
System image file is "flash:/c3560-ipbasek9-mz.150-2.SE11.bin"
Just to eb sure ive removed teh MLS globally and from interface level and reapplied auto qos
defaulted back to this
interface FastEthernet0/9
Then reapplied just auto , it comes out same as this reapplying the MLS too but still no policy, this is what i always see like MLS takes pref on an MLS QOS type switch
priority-queue out
mls qos trust dscp
auto qos trust dscp
This compared to my 36s IOS-XE which generate the actual interface policies and class maps , i though MLS switches never do that
interface GigabitEthernet1/0/20
description xde-ap1
switchport access vlan 5
switchport trunk native vlan 5
switchport mode trunk
auto qos trust dscp
spanning-tree portfast trunk
service-policy input AutoQos-4.0-Trust-Dscp-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
On a switch where it fully uses Auto Qos instead of MLS you can run the full command check against the interface but on MLS you need to run show mls qos interface gx/x stati
#sh policy-map interface g1/0/3
GigabitEthernet1/0/3
Service-policy input: AutoQos-4.0-Trust-Dscp-Input-Policy
Class-map: class-default (match-any)
13101961642 packets
Match: any
QoS Set
dscp dscp table AutoQos-4.0-Trust-Dscp-Table
