Why there is no ping
ehsan.zirend1
Hello guys,in packet tracer I put two pc and two 2960 switches.in order to aggregation, Switches linked with three Cables. each Interface in each switch grouped together.channel protocol is LACP and mode of one switch is Active and other is Passive.up to now I have ping,but when I shut down three Interface of passive switch and then power up, although every interface is green but I have no ping.What is wrong??
Thanks for your reply.
9 Replies 9
can you save the project and post the.pkt file ?
Website doesn't allow upload .pkt files.
I uploaded  a picture
the website allows zip files, I would zip the pkt file and post it. That way, we immediately have all your configs.
thanks for your reply , it was uploaded
with the configuration you sent me, you have a native Vlan mismatch between the port channel (native Vlan 1) and the access ports (Vlan 10). The only way I got this to work is with the config below:
interface Port-channel 1
switchport mode trunk
interface FastEthernet0/1
switchport access vlan 10
channel-group 1 mode active
interface FastEthernet0/2
interface FastEthernet0/3
channel-group 1 mode passive
So why for  the first time ,it was configured in that way,I had ping  ??
I think , found the answer. gpauwen ,we can do Access between switches.[https://supportforums.cisco.com/discussion/11115756/can-we-connect-two-switches-when-using-access-mode].
when one switch is Passive ,  we have no ping. but when both switches are Active -Active, everything is fine.when one switch become passive, it just respond, no negotiation, but we created two Vlan in switches. switches must negotiate with each other to identify Vlan .
Interesting...good stuff ! I am currently labbing this in GNS3, I let you know if I get the same results...
I did as you said but when I shut Fast Ethernet 0/1- 3  one by one and again power up ,the colour of Passive ports are Orange and I have no ping, what is wrong??
I use version 6.2.0.0052 packet tracer for student
Again, Thanks for your reply
