WIC-2t vs ethernet
fran19422
Hello, if you had a small network with a few routers in a building, would you connect them with ethernet rather than serial (like a WIC-2t interface).
Is the serial method of interconnecting routers (e.g WIC-2t) an old method that has been superceded by ethernet now ?
Thanks for any help.
Reza Sharifi
Since this is all within the same building you connect the routers together using Ethernet ports.  If the distances are great (between buildings, Cities, countries, etc..) than you use a services provider and one method of connecting them would be using serial (T1) interfaces.
Reza Sharifi
Leo Laohoo
Serial has been superseded by ethernet because it's expensive to cable up links like that.  Hardware manufacturers are not keen in keeping serial interfaces alive because it takes a lot of expensive "real estate" on the appliance.
Think about it:  How many RU do you need if you have a 24-port SERIAL interface switch or router?
Another thing is the distance and bandwidth you can push on a serial interface against ethernet (copper or fibre optic).
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
BTW, when using Ethernet within a LAN you would often want to use L3 switches.  Most small routers with Ethernet interfaces do not have actual performance to route at wire-speed.
Also BTW, today, "typical" Ethernet will provide over 50x the bandwidth of "typical" Serial.
