WIC and NM..what is the difference?
newnetman
Could someone please help to explain the difference between WIC (Wan Interface Card) and NM (Network Module) cards for me?.
I thought these are just the same or not?
Thanks in Advance
JORGE RODRIGUEZ
Level 10
Level 10
NM network module refers to the expantion slot where allows for installation of other interfaces that provides for various services depending on the platform for example you may find a 16 port switch module or a two FE module to be installed in the NM slot etc.. you would see the part number begining with NM , the WIC cards are mostly wan cards E1, T1 etc, you could also find a network module where you can install WIC cards as well..
Jorge
Jorge Rodriguez
ccbootcamp
Level 7
Level 7
WIC cards are little NM cards are bigger. :)
Feature cards, interfaces, etc, can come in NM or WIC cards. Just make sure the card you are using is supported by the router you want to use it in. Routers which have WIC and NM slots typically have more WIC slots than NM slots.
This is a very general question, but hopefully I provided some insight for you.
-brad
www.ccbootcamp.com
(please rate the post!)
curci
Both WIC and NM are families of interface
cards used in the Cisco 26xx, 28xx, 37xx,
38xx routers. WIC = Wan Interface Card,
NM = Network Module?
For example, the Cisco 2811 router can
accomodate four WIC cards and 1 NM card.
Generally speaking, the NM card is used
for applications with higher density.
For example, if you need an asynchronous
serial card, Cisco has both an 8-port WIC
card, but also makes 16-port and 32-port
NM cards.
