Will my access-list work on home LAN ?
Hi everyone,
Could you please look into my access-list applied to my router and tell me if this will be enough to secure home network.
I use Cisco 887W router with the following scenario: VLAN1 & WLAN1 - 192.168.1.0 255.255.255.0 defaul gateway - 192.168.1.1
VLAN10 - connection to ISP using dynamic dhcp.
I came up with the following access-lists:
version 15.4
no service pad
hostname Cisco887W
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
clock timezone NZST 12 0
clock summer-time NZDT recurring 1 Sun Oct 2:00 3 Sun Mar 3:00
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool Pool1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
domain-name local
dns-server 4.2.2.2
ip domain name local
ip inspect name OUTSIDE ftp
ip inspect name OUTSIDE icmp
ip inspect name OUTSIDE tcp
ip inspect name OUTSIDE udp
ip inspect name OUTSIDE dns
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO887W-GN-A-K9 sn FGL1539201C
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
description UFB
switchport access vlan 10
switchport mode trunk
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface wlan-ap0
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
ip access-group VLAN-1 in
ip flow ingress
ip nat inside
ip virtual-reassembly in
interface Vlan10
description UFB
ip address dhcp
ip access-group VLAN-10 in
ip accounting output-packets
ip flow ingress
ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Vlan10 overload
ip route 0.0.0.0 0.0.0.0 Vlan10 dhcp
ip access-list extended OUTSIDE
permit ip 192.168.1.0 0.0.0.255 any
deny ip any any
ip access-list extended VLAN-1
permit udp host 0.0.0.0 eq bootpc host 255.255.255.255 eq bootps
permit ip 192.168.1.0 0.0.0.255 host 192.168.1.1
ip access-list extended VLAN-10
permit ip 192.168.0.0 0.0.1.255 any
permit udp host 192.168.1.1 eq ntp any
permit tcp any any eq 3389
permit udp any eq domain any
permit icmp any any unreachable
permit icmp any any echo-reply
permit icmp any any packet-too-big
permit icmp any any time-exceeded
permit icmp any any traceroute
permit icmp any any administratively-prohibited
alias exec c copy running-config startup-config
alias exec s show ip interface brief
line con 0
logging synchronous
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
login
transport input none
ntp server 203.173.195.107
end
Please let me know if this configuration will work.
Shawn Guertin
I don't know what are the best practices, but I would use an access list on the line vty 0 4 as there are random robots scanning the internet (even residential IPs) for SSH and try common username and passwords. here is an example of sho log:
Jun 22 09:03:42: %SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: ftpuser] [Source: 109.236.24.191] [localport: 22] [Reason: Login Authentication Failed] at 09:03:42 EDT Mon Jun 22 2015
Jun 22 09:05:37: %SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: cisco] [Source: 182.75.48.102] [localport: 22] [Reason: Login Authentication Failed] at 09:05:37 EDT Mon Jun 22 2015
Jun 22 09:11:11: %SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: ubnt] [Source: 115.248.25.5] [localport: 22] [Reason: Login Authentication Failed] at 09:11:11 EDT Mon Jun 22 2015
I can't help you overly secure your WAN access since I only use the Nat as an input restriction, but I used an NSA doc to secure the router itself: https://www.nsa.gov/ia/_files/switches/switch-guide-version1_01.pdf
I have a 881 at home, the difference comes from interface Fa4, its a router interface (no need for a Vlan10). You might be curious so I will allow you to compare:
 no ip address
!On Vlan 1 by default
 no ip address
 no ip address
 no ip address
interface FastEthernet4
 description WAN Interface
 !This model has a router interface
 ip address DHCP
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 duplex auto
 speed auto
 no cdp enable
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip unnumbered Vlan1
 arp timeout 0
 no ip address
interface Vlan1
 description Main Vlan
 ip nat inside
ip nat inside source list NAT-List interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.10 80 interface FastEthernet4 80
!The last one was to redirect external http requests to 192.168.1.10
ip route 0.0.0.0 0.0.0.0 dhcp
ip access-list standard NAT-List
 permit 192.168.1.0 0.0.0.255
ip access-list standard SSH-Access
 deny   any
line con 0
 no modem enable
line aux 0
line 2
 no exec
 transport input all
 access-class SSH-Access in
 exec-timeout 60 0
 transport input ssh
end
