Wireless bridge output drops
dan.letkeman
Level 4
Level 4
I have two locations each with a 3560G and a wireless bridge between them capable of 60Mbps TCP.  I am seeing output drops on the 3560G's because of the limited bandwidth of the wireless link, and I have setup the ports on the 3560G's as follows but I continue to have output drops.
description TR-BVS
switchport trunk native vlan 2089
switchport trunk allowed vlan 2089
switchport mode trunk
bandwidth 60000
speed 100
srr-queue bandwidth shape 10 2 0 0
srr-queue bandwidth limit 60
priority-queue out
mls qos trust dscp
GigabitEthernet0/20 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 64d9.8981.d994 (bia 64d9.8981.d994)
  Description: TR-BVS
  MTU 1500 bytes, BW 60000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 3/255, rxload 21/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:19, output hang never
  Last clearing of "show interface" counters 2w0d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 243060
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 5992000 bits/sec, 734 packets/sec
  5 minute output rate 1075000 bits/sec, 476 packets/sec
     496160280 packets input, 479198649478 bytes, 0 no buffer
     Received 1029994 broadcasts (989434 multicasts)
     0 watchdog, 989434 multicast, 0 pause input
     334695405 packets output, 90549065701 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Is there anything else I could try on these switches to see if I could elimiate the output drops?
Dan.
0 Replies 0
