wireless c3702e
NITIN RAI
Community Member
“We are deploying Cisco wireless solutions and chosen series 3702e, this model seems to be best suitable as per our specs. We need to buy a compatible antenna and AIR-ANT1728 looks suitable as we have bigger area to cover and need strong signal strength over all places. Can someone please help me to find out if it is technically compatible.”
 Thanks & Regards
Nitin Rai
Philip D'Ath
Meraki Community All-Star
Is this an indoor area?
Based on what you have said, I think you would be better off using more access points with standard antennas, than using less access points with high gain antennas.  And if it is indoor I would use the 3702i to save money.
