Wireless mobility groups on WLC
carl_townshend
Hi all, when I configure my controllers to be in the same wireless mobility group, If I make a change on one controller to one my my ap,s will this reflect on the other controller? or will I have to configure them both?
Steve Lyons
Mobility groups provide redundancy between WLCs for APs. If you want to use synchronized configurations on both WLCs within a mobility I would recommend using WCS. To further answer your question yes you will need to configure both WLCs. If you use WCS to configure the WLCs you will only need to configure the WCS.
