wireless problem
rollie
Please any one can solved my problem
Thank you
i have both cisco router and switch, my wireless connected to a switch, the pc connected to the wireless can ping the router which is the switch is connected to the router, but the pc that is connected to switch can ping the wireless ..please help if there are any setting that i missed.
9 Replies 9
Hi @rollie
What do you mean by "but the pc that is connected to switch can ping the wireless " ?
 You mean you can ping the Access Point connected to the Switch? What´s wrong with that?
-If I helped you somehow, please, rate it as useful.-
apologized to my mistake* "**but the pc that is connected to switch cant
ping the wireless"*
Still unclear what you mean by wireless. If you refer to the AP, make sure you dont have a ACL on it. AP should respond  ping from the network considering default behavior.
Thank for the replies problem solved already
in addition to Flavio's post - what router and switch model do you use ? What are the IP addresses and default gateways of the PC and the 'wireless' ? Post the configurations of the devices you have in your setup...
here is my router setup
WAN
g0/0 ip address 100.100.100.22 255.255.255.252
no shutdown
LAN
g0/1 ip address 192.168.99.1 255.255.255.0
no shutdown
ip dhcp excluded-address 192.168.99.1 192.168.99.200
ip dhcp pool LAN
network 192.168.99.0 255.255.255.0
default-router 192.168.99.1
dns-server 8.8.8.8 4.2.2.2
access-list 1 permit 192.168.99.0 0.0.0.255
ip nat inside source list 1 int g0/0
ip route 0.0.0.0 0.0.0.0 100.100.100.21
my switch configure to a vlan 99 that is directly connected to the router
AP is connected to my switch on port 24 which also belong to the vlan 99
the ip address of my ap is 192.168.99.204 which the router cant ping.
Hello
How is this ap connecting - what mode it is using?
can you ping the Ap from the router
res
Paul
Kind Regards
Paul
i cant ping the AP from my router, the switch connected to the router, and
the ap is connected to the switch.
Hello
Is your pc is connected wireless to the AP and are you receiving an ip address from the dhcp off the rtr?
On the AP, You'll need to have setup at least a SSID and associated that with a radio /physical interface and created a BVI mgt connectivity.
Can you post the config of the AP please.
res
Paul
res
Paul
Kind Regards
Paul
