without qos configured
ciscoforum
If a 3550/3750 switch is not qos enabled and IP phone connects to it. How does it happen when packets arrive on the outbound interface to wan(dot1q between them):
1. dscp reserved?
2. how about cos? since no qos enabled, switch won't look at the default dscp-cos map. Will the cos be reserved or 0? Thanks
kerek
Level 4
Level 4
The default egress queuing is FIFO. If the packets are marked by the IP phone it will be carried over intact. The CoS will be 0 out trunk interface.
Krisztian
