WS-C2960PD-8TT-L PoE input
armingojak
How can I activate power input on WS-C2960PD-8TT-L on gigabit ethernet 0/1 PoE input interface...?
I have AIR-PWRINJ4.
Regards.
agugger
Hello Armin
Here a copy from the data sheet:
(http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html)
The Cisco Catalyst 2960-8TT-L has eight 10/100 ports with one 10/100/1000 POE INPUT PORT. This switch does not need a power supply and receives power over the uplink from an upstream PoE device, providing deployment flexibility and availability. It is ideal for wiring and space-constraint applications. The power adaptor (PWR-A=) and power cord are optional and may be ordered separately.
This mean this particular switch can run without an AC power supply and take his power from other switch how can serving PoE as output
Also the eight 10/100 ports give NO PoE out.
So you need a different switch how is able to deliver PoE out.
Andy
hi,
i know that, but when i connect power injector to my switch nothing happen. it not boot up, while it is ok when it connect to standard power adapter.
so i need to know, dose here any command that i need to write in CLI to define which power source to use...?
