WS-C3750E-24TD
parmodg85
I have C3750E switch, and it is in stack. I am managing both the switches with management interface fa0, which is for Master switch in stack. But while I check for management interface for Slave switch using show int des, I dont see any interface for that.
My query is, what would be the status of management interface of slave switch in case of stack, when I do have have slave switch is also connected with same core switch as Master switch. It would be disabled or down, or it will not be shown in config.
Parmod
Rajeev Sharma
Hey Pramod,
Regarding your query:
My query is, what would be the status of management interface of slave switch in case of stack, when I do have have slave switch is also connected with same core switch as Master switch. It would be disabled or down, or it will not be shown in config. - On slave switch it will be disabled and will not show in the configuration. You may check the configuration guide:http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swint.html#wp1730167
Although it doesn't specifically answer your query but my as per my understanding fa0/management port will be available on master switch only.
HTH.
RS.
