is there anything I can do on a 3750G-12S on this switch stack to prevent the switch from bursting out multicast
Problem Details: We have a stacked Core Switch (WS-3750E-24PD + WS-C3750G-12S). We
send/receive multicast at 270M in both directions throug a fiber port on the 12 port
switch out interfaces on the 24 port copper switch. We are dropping packets on clients
and noticed that the data rate counter on the fiber swtich fluctuates between 250M and
350M - which indicates to me that its bursting the traffic in/out. I moved the router we
are connected to on the fiber interface down to an open fiber port on the 24 port switch
and there was no bursting or rate variance. Im assuming this means that either between
the two switches there is an issue in sending data through the stack or the 12 port
swtiches are not metering the traffic right.
