11-17-2011 07:52 AM - edited 03-07-2019 03:27 AM
I have a WS-C3750G-24TS-S1U switch. I would like to know if IP SLA icmp echo is supported in IPservices featureset. I have checked the feature navigator and this switch model seems to be missing. It would be great if someone can confirm or deny this
11-17-2011 08:02 AM
Yes, it is supported:
Switches running the IP base image support only IP SLAs responder functionality and must be
configured with another device that supports full IP SLAs functionality, for example, a Catalyst 3750
switch running the IP services image.
here is more info on how to configure IP SLA ICMP:
11-17-2011 08:19 AM
Thanks. I am after using IP SLA on the 3750 for monitoring couple of static routes using icmp-echo
