WS-C4506-E upgrade to release 03.06.04 supervisor WS-X45-SUP7-E
Augustgood
Hi all,
I will upgrade my 4500-E without lose client services (using ISSU), someone can help me to find the right procedure ?
this is the actual release :03.06.03
this is the release to put in the device :03.06.04
I found this white paper http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/white-paper-c11-732289.html
someone test this procedure ?
Thanx all
Carlos Villagran
Hi!
Please refer to the following for the detailed ISSU upgrade process:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/31sga/configuration/guide/config/issu.html
Hope it helps, best regards!
JC
