WS-C6509 - Power Supply
jorgesaraiva
WS-C6509 switch supports two models of power supply in the same chassis?
for exemplo :
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-3000W       1171.38 27.89  -      -      off
2    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
Note: PS2 capacity is limited to 2940.00 Watts (70.00 Amps @ 42V)
      when PS1 is not present
Reza Sharifi
If you use 2 PSUs with the different wattage in the same chassis then you can not use them in redundant mode which is default.
You can use 2 different PSUs in the same chassis in combined mode only.
Mode info here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/pwr_envr.html
Reza
Reza Sharifi
Mode info here:
Reza
Leo Laohoo
It will work ... as long as the bigger PSU doesn't fail.    In regards to the status of the line cards will depend on what they are.
