WS-SUP720-3BXL
ishwarshrestha
need to replace supervisor engine WS-SUP720-3B with WS-SUP720-3BXL on 6509 chasis
Please let me know what is the  best way to do it.
Reza Sharifi
Should not be an issue.  Just make sure you have a good copy of the config before replacing the sup.
Hi Ishwar,
refer the below doc for detailed steps to replcae the sup module and as stated by reza make sure you have a good copy of the existing configuration:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/91897-replace-frsm-cat65k.html
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-virtual-switching-system-1440/109334-replace-vss-sup-proc-v1.html
-Do rate all helpful posts.
As Reza mentioned there is no issue with replacing it. Please check the link below for the procedure of safe installing.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Module_Installation/Sup_Eng_Guide/supe_gd/03instal.html
Masoud
