08-10-2007 05:58 AM - edited 03-05-2019 05:49 PM
Looking for a compatibility check for 100FX SFP modules in a 4506 switch using the 4506-GB-T interface. Specifically extending distance over MMF. I will be going from the 4506 to 3750's, 3560's, 2960's series switches.
Solved! Go to Solution.
08-11-2007 04:10 PM
100FX SFP modules will not work in that line card. The only line card we could get to accept 100FX SFPs was the WS-X4248-FE-SFP module.
08-11-2007 04:10 PM
