WS-X6708-10G-3CXL card insertation killed VSS and fan-tray went to high speed
rocketrach
I currently have a VSS setup on 2 6509-E using 2x VS-S720-10G.
Today I tried to install 2x X6708-10G-3CXL, one into each chassis.
The first log message I got was that fan tray was going into high-speed mode, is this correct?
I then installed the second card in the 2nd chassis and it killed my VSS and proceed to reload the switches. it now also appears to have killed one of my WS-X6724-SFP cards, as it no-longer boots and I get the following errors:
000249: Jan  8 12:52:34.201 GMT: %DIAG-SW1_SP-3-MAJOR: Switch 1 Module 1: Online Diagnostics detected a M
ajor Error. Please use 'show diagnostic result <target>' to see test results.
000250: Jan  8 12:52:34.205 GMT: %CONST_DIAG-SW1_SP-3-BOOTUP_TEST_FAIL: Switch 1 Module 1: TestLoopback f
ailed on port(s) 1-24
000251: Jan  8 12:52:35.049 GMT: %OIR-SW1_SP-3-LC_FAILURE: Module 1 has Major online diagnostic failure,
Card will be powered down. Please check bootflash diaginfo file for detailed diagnostic result.
Also I can't read any of the log files in 'bootflash diaginfo' as it says the file doesn't exist.
Everytime I know re-insert the WS-X6724-SFP cards it kills the VSS
I appreciate this is a bit of a generic question, but has anyone got any ideas? Any help would be much appreciated.
Thanks in advance
Rob
Rob,
You defiantly need an upgrade.  I know that SXI4a is a pretty good code, but I have heard the latest code (SXJ) is also pretty solid.
Good Luck
Reza
14 Replies 14
Reza Sharifi
Hi Rob,
Is your Sup 3C or 3C-XL?  If your Sup is 3C then you need a 3C line card.
Hi Reza,
Thanks for getting back to me
The Sup is the 3CXL
It looks like I may of come across this little bug: CSCtb47692
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtb47692
Rob
Rob,
What version of code are you running?  This bug is pretty old, because it was found in SXI which is over 3 years old and was fixed in SX4 which is about 2 years old.
Reza
Hi Reza,
We are currently running 12.2(33)SXI2, which like you say is old. I guess an upgrade is going to be needed.
Thanks again for your help
Rob
Rob,
Good Luck
Reza
I'll have a look at both
Thanks very much
Fingers crossed
Rgds
Rob
Rob,
One more thing I forgot to mention in my previous posts.  Make sure your line cards also have the latest firmware on them. I have seen issues with running older firmware on X6708 cards.
Here is the latest:
http://www.cisco.com/cisco/software/release.html?mdfid=278110069&flowid=190&softwareid=280805687&release=12.2%2818r%29S1&relind=AVAILABLE&rellifecycle=&reltype=latest
Reza,
So what would be the best way of doing this?
Break VSS first, then Firmware upgrade then code upgrade?
Rob
Hi Leo,
This is the only document I could find. Not sure if it is helpful.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/rommon/OL_6010.html
Thanks.  (+5)
Currently using SXJ1.  Feels better than the SXI-series IOS.
Just looking for a little bit of advice.
Will I be OK doing a eFSU Upgrade from s72033-ipservicesk9_wan-mz.122-33.SXI2a to s72033-ipservicesk9_wan-mz.122-33.SXJ1?
I only have a single supervisor in each chassis.
Should I be ok with just following the eFSU upgrade instructions in the below?
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1133416
Thanks in advance for any advice
Best Regards
Rob
Rob,
Yes, you are going from a non-modular IOS to another non-modular, so you are fine.
Single Sup in each chassis is fine.  That is what originally VSS was design with.
Make sure to follow the link step-by-step.
Even though using eFSU supposed to be none disruptive, make sure you do this during an outage window. (after hours)
Leave extra time for doing this, since the chassis will be booting multiple times, and each time can take up to 15 Minutes (depending on the number of modules you have in the chassis) to boot.
Good Luck,
Make sure to follow the link step by step. Also, you should be fine with one Sup per device.
