05-28-2015 02:57 AM - edited 03-08-2019 12:14 AM
I need an information,
I have a catalyst 6509-E with WS-SUP720-3B ( with IOS 12.2(18)SXE3 that I want upgrade to 12.2(33)SXI13 ) and WS-X6708-10G-3C ,
I would like to install an X2-10GB-T on WS-X6708-10G-3C module , but in this link
suggest to upgrade to 12.2(33)SJI1 as Minimum Software Release Required to support the X2-10GB-T
But 12.2(33)SJI1 does not exist......
anyone has information about ???
Solved! Go to Solution.
05-28-2015 03:50 AM
Most likely a typo - Release Notes say that X2-10GB-T is supported since 12.2(33)SXJ1:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/release/notes/ol_14271/features.html#pgfId-4805429
05-28-2015 03:50 AM
05-28-2015 05:41 AM
Thank You Iulian.
10-18-2016 10:47 PM
Thanks Lulian.
