xconnect between different vlans
draganskundric
can I use xconnect session between two routers that have interfaces in different VLANs. On one side it is vlan 154 and on the other xconnect is terminated on interface that is in vlan 144?
Dragan,
I quickly checked with the Feature Navigator and it appears that VLAN ID Rewrite feature is supported only in 12.4T.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
15 Replies 15
Harold Ritter
Dragan,
This will work indeed.
Are you sure? Looks like it does not work
I agree with hritter.
It works in the same way as if you connected a cable between the two VLANs, if that's what you really want to do?
Please post your xconnect config for both sides. Is it AToM or L2TPv3?
router a
interface GigabitEthernet0/0.55
encapsulation dot1Q 155
xconnect 5.5.5.5 55 pw-class class
router b
encapsulation dot1Q 55
xconnect 4.4.4.4 55 pw-class class
so if I have same vlan on both sides, then it is ok, but if I change vlan on one side, then it does not work
Dragan,
What platform is this?
7200
Dragan,
Do you use a 7200 at both end? The 7200 platform does support vlan rewrite automatically. There is no need for special configuration. How did you test that it does or does not work? When you changed the vlan on the 7200 did you also changed it on the CE?
Can you post a "show mpls l2 vc detail"
yes and yes I've changed it on all nesessary places. How to configure vlan rewrite? I do not have this mpls command
Dragan,
As I stated in my previous post, there is no command to enable vlan rewrite on the 7200. it is done by default.
Can you please post the output requested and also let us know what level of code you are running on the 7200s.
i cannot post you an ouput because I do not have command you are talking about. Ios is c7200-ik9o3s-mz.124-12c
Dragan,
Here is the command from a device with the same train you are running:
CE1#sh mpls ?
forwarding-table Show the Label Forwarding Information Base (LFIB)
interfaces Per-interface MPLS forwarding information
ip MPLS IP information
l2transport MPLS circuit transport info
label Label information
ldp Label Distribution Protocol information
static Show MPLS static information
traffic-eng Traffic engineering information
CE1#sh mpls l2 ?
binding Display VC label binding information
hw-capability Show MPLS L2 transport capability
summary Show summary of l2transport
vc Display VC(s) info for circuit transport over MPLS
CE1#sh mpls l2 vc ?
<1-4294967295> VC ID or min VC ID value
destination Destination address of the VC
detail Detailed information
interface Local interface of the VC
vcid VC ID or min-max range of the VC IDs
| Output modifiers
CE1#sh mpls l2 vc
well mybe you have it .... but I do not
Dragan,
I've upgraded routers and it does not work
