xmodem connection very slow
raulblanco122
Hello.
I have a cisco 876;
I'trying to put a file via xmodem, but it takes about 5 minutes on putting a 6KB file.
I configure the xmodem connection to 9600 b.
it is very slow, so anyone knows if I have to change any configuration of the port.
thanks
please try out the following procedure and let me know the results:
turn down the router and take it to rommon mode
rommon1>confreg 0x3920
rommon2>reload
change the speed of the console to 115200 keeping the other settings and start the connection again.
rommon1>xmodem -cr c8xx-xxxx-mz.124-x.bin
It will speed up the transfer rate, probably it will take about 30 minutes for a 12 Mb file,
Hope this helps,
Thanks for the help!!!
