xp hyper terminal scrolling problem
Ofir-Yeshayahu
Community Member
Does any one know how to set hyper terminal setting so scrolling will be available and won't go wrong?
Ofir.
mohammedmahmoud
Level 11
Level 11
You can increase the scrollback buffer settings.
HTH,
Mohammed Mahmoud.
I have a better idea: Dont use Hyperterminal -- its garbage. Download Putty (its free) or use Secure CRT.
Thanks for your response.
I tried changing the buffer but there is no change. I'm able to see parts of the configuration (after "show run" the first 24 raws ok and the rest go wrong). I'm using vt100 terminal (tried others too):
Unfortunately I have to use only hyper terminal..
