04-01-2025 02:55 PM
I have existing HP switches 10/100 48 Port POE Switch HP2620-48 with existing configuration and i would like to move the configurations to the new Cisco CSC-C9200L-48P-4X-E 31 switches. Is there a tool I could use or a procedure or process?
04-01-2025 11:17 PM
check some reference post : (add the configuration and test it) - you may not get 100% like a like but functional should work.
Good to understand HP syntax vs cisco config syntax, help you to troubleshooting.
https://community.cisco.com/t5/switching/migrate-from-hp-to-cisco-vlan-configuration/td-p/4143573
https://community.cisco.com/t5/switching/translate-configuration-from-hp-to-cisco/td-p/4848783
https://learningnetwork.cisco.com/s/question/0D53i00000Kt3vBCAR/switch-migration-hp-to-cisco
BB
Log in to Community
