Request Visio Stencil for Catalyst 8300/8500
Greetings,
Requesting stencils for Catalyst 8300 and 8500, or at least the location in case I missed it.
balaji.bandi
this is latest what cisco has : (until anything shared privately not aware of)
https://www.cisco.com/c/en/us/products/visio-stencil-listing.html
BB
9 Replies 9
balaji.bandi
BB
Can we get Cisco Catalyst 8200 Stencils? I'm not sure why there would be 8300 and 8500 but not 8200.
Is there any visio stencil that contains C-NIMs and C-SMs?
staswright
The 8200 is in the existing stencil, but I'm guessing it's not correct.  8300 is missing.
LenderS
Esteemed, bumping this thread as we are in dire need of a stencil for the sixteen-port NIM module for the 8000 series routers.
Part number: C-SM-16P4M2X
Bumping as I also need the cisco 8300 series stencils which are currently missing as well as the C-SM-16P4M2X service module that can be installed into it
tcanthonyii
Same as LewJack1980_.  I need the 8300 stencils as well.  why after so long has this not been provided?
hemmerling
I see that there are Edge 8300/8500 stencils, and if they weren't in a format from 20 years ago (.vss) I might be able to open them and use them (blocked by security policy because the 20+ year format is less secure).
Can Cisco maybe release them in the newer .vssx or maybe both.
I ran into the same problem and used this free converter: https://products.groupdocs.app/conversion/vss-to-vssx
Seriously, it worked. 🤷‍
