- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-27-2016 06:33 AM - edited 03-20-2019 07:47 PM
We are trying to document probable configurations for replacing our 2900 and 3900 Series Routers with 4300 and 4400 Series Routers. Several Stencils are notably missing from the Stencil Library. 1) The redundant Power Supplies for the 4431 Router and 2) The NIM-2GE-CU-SFP Module.
Any help in having the Stencils created would be appreciated
Solved! Go to Solution.
- Labels:
Technical Documentation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-28-2016 11:09 AM
Hi Eric
I am going to assume you looked into
http://www.cisco.com/c/en/us/products/visio-stencil-listing.html
but did not find stencil/icons for 1) The redundant Power Supplies for the 4431 Router and 2) The NIM-2GE-CU-SFP Module.
Would this be a safe assumption?
If yes, let me know and I can approach the Cisco business folks to see what can be done.
Kind regards .... Palani
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-28-2016 11:09 AM
Hi Eric
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2016 12:20 PM
Hi Eric
Regret the delay. Still working on identifying the correct group/folks.
Kind regards ... Palani
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-07-2016 02:10 PM
Hi Eric
Very very slow progress from our end. Regret inconvenience caused. I have got traction with the team that handle this. Our product team is working on adding stencils for other missing parts. Neither NIM-2GE-CU-SFP nor PWR-4450-DC/2 or PWR-4430-DC/2 are in the proposed list.
Right now, we are discussing what it would take to add these missing to the "work in progress". Please hang in there for my next update.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2016 11:24 AM
Hi Eric
You have been very patient. Thank you. I am unable to upload the VSS file indirectly. I could not upload if the extension was vss. So, I changed the file ext to doc. After downloading, please change from doc to vss and you will be able to access the template.
Let me know if you it is not working for you and I can think of alternate options.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-22-2022 01:26 AM
Is there a similar Visio with the NIM-16A cards?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-24-2019 02:57 PM
Is there a similar template (.vss) with the PWR-4330-DC?
Thank you,
Ken
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-28-2016 11:25 AM
Palani
Correct, I was looking in the "Routers - ISR 4000" (ZIP - 4 MB) 09/Aug/2016 Zip file for both items. I also searched other Zip files of routers that support NIM Modules to see if the NIM-2GE-CU-SFP might be contained in another location but wasn't able to locate it.
I would appreciate it if you could get them created
Thanks in Advance -- Eric
