About cms webrtc access using android webview
anyway60419
I want to connect to cms webrtc using webview on android.
However, when connecting to webrtc through webview, it appears as a browser that is not supported.
Cms webrtc doesn't support android webview? Or is there another way?
Jaime Valencia
The online documentation contains the list of supported browsers for WebRTC with CMS, did you review it?
java
if this helps, please rate
I saw the document.
When I access WebRTC with CMS from android webview, it says that it does not support browser, so I asked if WebRTC with CMS supports android webview or not.
What is listed in the documentation is what is supported, anything NOT listed is considered NOT supported.
java
